When starting Openwindows from the command line, the following error message is echoed on the Solaris "Welcome" screen: fbconsole: ioctl SRIOCSREDIR: Device Busy
Once inside Openwindows, The following message is displayed in the background windows and when starting cmdtool -C:
SYSTEM WARNING: Object 0x340f8, Device busy, ioctl SRIOCSREDIR returned -1, attempt to make tty the console failed (Tty package)
Openwindows was probably started in the background (using the "&"). Exit Openwindows, and run the command in foreground: /usr/openwin/bin/openwin
If this doesn't help, then perhaps some daemon or process is "holding" the console. Type the command: fuser /dev/console.
A list of process id's is returned. Examine these processes to determine if an application has hold of the console (using the ps(1) command, will help).
