If you are certain that the diskette contains no data, run fdformat -d to format the diskette in DOS format. (You can also format a diskette in UFS format if you like, although then it cannot be transported to most other systems.) When the diskette is formatted, you can write on it, if it was not corrupted beyond repair.
