Check that the license daemon is running on the server. Then...
Case one: Workaround: Ignore the messages. Solution: Upgrade to 2.1c or above.
Case two: To check for a misassigned license, run the command hostid(1). Your hostid is displayed.
Now run the command fw printlic. You will see output like this...
This is FireWall-1 Version 2.1 Type Expiration Features id-649f152b never stdlight |
