This message appears in the SCSI log to indicate that a read or write operation has been retried until it timed out. With SCSI disk the timeout period is usually 30 seconds; with tape the period is usually 20 attempts. Timeout periods are generally coded into the drivers.
Check that all SCSI devices are connected and powered on. Make sure that SCSI target numbers are correct and not in conflict. Verify that all cables are no longer than six meters, total, and that all SCSI connections are properly terminated.
The scsi_log(9F) routine usually displays messages on the system console and in the /var/adm/messages file. Run the dmesg(1M) command to see the most recent message buffer.
