This message can appear on SPARCservers or x86 machines with an Intel 82586 Ethernet chip. It indicates that the chip has lost input to its carrier detect pin while trying to transmit a packet, causing the packet to be dropped.
Check that the Ethernet connector is not loose or disconnected. Other possible causes include an open circuit somewhere in the network and noise on the carrier detect line from the transceiver. Use snoop(1M) or a similar program to isolate the problem area, then check the network connectors and transceivers, as needed.
