If you are booting from CD-ROM or from the net, check README files to make sure you are using an image appropriate for your machine architecture. Run df(1M) to make sure there is enough swap space on the system; too little swap space can cause this error. If you recently upgraded your CPU to a new architecture, replace your operating system with one that supports the new architecture (an operating system upgrade might be required).
