This fatal X server error message indicates that /dev/fb, the "dumb frame buffer," is either missing or corrupted. It is usually followed by a "giving up" message and a few xinit(1) errors.
If other devices on the system are working correctly, the most likely reason for this error is that the SUNWdfb package was removed or never installed. Insert the installation CD-ROM, change to the Solaris_2.x directory, and run the following command to install the packages SUNWdfbh and SUNWdfb (for your machine architecture):
pkgadd -d . |
If other devices on the system are not working correctly, the system might have a corrupt /devices directory. Halt the system and boot using the -r (reconfigure) option. The system will run fsck(1M) if the /devices filesystem is corrupted, most likely fixing the problem.
