Applications have recently begun to fail with this error: ld.so.1 fatal: can't set protection on segment. The failures are random.
This was happening because of the recent introduction of a rogue application that consumed most of the swap space on the system. The other applications, which failed randomly, were doing so because of insufficient swap space to run. The error from ld.so.1 happened because there was no segment on which to set the protections.
