This message is produced in Solaris 2.6 and later releases. It is not produced in Solaris 2.5.1, or earlier releases.
This message indicates that the run time linker, ld.so.1(1), while running the program specified after the first colon, could not find the shared object specified after the third colon. (A shared object is sometimes called a dynamically linked library.)
As a workaround, set the environment variable LD_LIBRARY_PATH to include the location of the shared object in question, for example:
/usr/dt/lib:/usr/openwin/lib |
For more information about the Linker, see the Linker and Libraries Guide.
