Standalone machines with no Ethernet port connection get this error when the system tries to access the network. If the Ethernet cable is disconnected, SPARC machines with the sun4m architecture usually display this message, whereas machines with the sun4c architecture usually display the "le0: No carrier-- transceiver cable problem" message instead. If the Ethernet cable is connected, this message could result from a mismatch between the machine's NVRAM settings and the Ethernet hub settings.
