When a user runs mailtool(1) on a remote machine, setting the DISPLAY environment back to the local machine, this message might appear inside a dialog box window. The dialog box goes on to say that the Classing Engine must be installed to use Attachments. This problem occurs because rlogin(1) does not propagate the user's environment.
Exit mailtool(1) and set your OPENWINHOME environment variable to /usr/openwin. Then run mailtool(1) again. The error message will not appear, and you will be able to use Attachments.
Classing Engine is a new name for Tool Talk. Earlier versions of mailtool(1) said Tool Talk: TT_ERR_NOMP instead of Classing Engine.
