Many developers have found that third party software (such as Purify) can help identify memory leaks in their applications. If you suspect that you have a memory leak, you can use sar(1) to check on the Kernel Memory Allocation (KMA). Any driver or module that uses KMA resources, but does not specifically return the resources before it exits, can create a memory leak.
