An operation on a transport endpoint or pipe was not performed because the system lacked sufficient buffer space or because a queue was full. The target system probably ran out of memory or swap space. Any data written during this condition will probably be lost.
To add more swap area, use the swap -a command on the target system. Alternatively, reconfigure the target system to have more swap space. As a general rule, swap space should be two to three times as large as physical memory.
The symbolic name for this error is ENOBUFS, errno=132.
