Check that the user's home directory is mounted and is owned by and accessible to that user. Perhaps the automounter tried to mount the home directory, but the NFS server did not respond quickly enough. Try listing the files in /home/username. If the NFS server responds to this request, have the user log out and log in again.
It is possible that the automounter daemon is not running. Run the ps(1) command to see if automountd(1M) is present. If not, run the second command; if it appears to be wedged, run both these commands:
# /etc/init.d/autofs stop # /etc/init.d/autofs start |
/home auto_home |
+auto_home |
It is also possible that the NFS server has not shared (exported) this /home directory, or that the NFS daemons on the server have disappeared.
