During login file system full errors are seen and login fails with the message No utmpx entry.
This is caused by a full file system so that the system has no space to write its utmpx (login info) entry.
To get around this condition the system must be booted into single user mode. Then clear (do not delete) the files: /var/adm/utmp and /var/adm/utmpx. This can be done by typing:
#cat /dev/null > /var/adm/utmp #cat /dev/null > /var/adm/utmpx |
In some cases after clearing these files the /var filesystem may still be full. In this case type:
du -askd /var |sort -nr |more |
