This error indicates that no system support exists for some function that the application requested.
Ask the system vendor for an upgrade, or contact the vendor or author of the application for an update.
This message indicates that no system support exists for an operation. Many modules set this error when a programming function is not yet implemented. If you are writing a program that produces this message while calling a system library, try to find and use an alternative library function. Future versions of the system might support this operation; check system release notes for further information.
The symbolic name for this error is ENOSYS, errno=89.
