To solve the first problem:
1. Check how the dfstab(4) (/etc/dfs/dfstab on the install image NFS server) looks:
share -F nfs -o ro,anon=o /jumpstart-dir |
2. Run share(1M) command on the installed image NFS server, to make sure it is shared properly.
3. Check /etc/bootparams file on the net install server. Look for entries with incorrect boot path.
4. Make sure that /usr/sbin/rpc.bootparamd is running on the boot server. If necessary, kill and restart it.
5. Check /etc/ethers on the boot server for duplicate or conflicting entries
6. At OK prompt, run test net /test-net and/or watch net /watch-net to test the network connectivity
A workaround for the second problem is to check the nsswitch.conf(4) file. If some of the entries point to NIS such as:
rpc nis files hosts nis files ethers nis files bootparams files nis |
rpc files nis hosts files nis ethers files nis bootparams files nis |
Then remove the client with rm_install_client(1M), remove the contents of tftpboot, and re-add the client:
add_install_client -c /jumpstart-dir/profiles 'client name' 'arch' |
