If you put the following lines into /etc/nsswitch.conf
passwd: compat passwd_compat: nisThen when you run passwd, it fails as follows:
server1% passwd passwd: Changing password for khh server1% |
If you read the man page for passwd very carefully, you will see the following:
If all requirements are met, by default, the passwd command will consult /etc/nsswitch.conf to determine in which repositories to perform password update. It searches the passwd(4) and passwd_compat entries. The sources (repositories) associated with these entries will be updated. However, the password update configurations supported are limited to the following 5 cases. Failure to comply with the configurations will prevent users from logging onto the system.
o passwd: files
o passwd: files nis
o passwd: files nisplus
o passwd: compat (==> files nis)
o passwd: compat (==> files nisplus)
passwd_compat: nisplus
NOTE: It does *not* say that you can use the line: passwd_compat: nis. If you conform exactly to what's written in the man page, then passwd(1) works.
