This message usually indicates that the system has a local filesystem mounted on /home, which is where the automounter usually mounts users' home directories.
When a system is running the automounter, do not mount local filesystems on the /home directory. Mount them on another directory, such as /disk2, which on most systems you will have to create. You could also change the automounter auto_home entry, but that is a more difficult solution.
