Remove the file named variable (where variable is the hostname) from both the /var/statmon/sm and /var/statmon/sm.bak directories. Then kill the statd daemon and restart it. If that doesn't get rid of the message, kill and restart lockd(1M) as well. If that doesn't work, reboot the machine at your convenience.
