If you just halted or rebooted the machine, don't worry-- this message is normal. In case of a system panic, look up the panic messages that appear above this one. Your system vendor might be able to help diagnose the problem. So that you can describe the panic to the vendor, either leave your system in its panicked state or be sure that you can reproduce the problem.
