A physical write error has occurred on the tar(1) output file, which is usually a tape, although it could be a diskette or disk file. Look on the system console, where the device driver should provide the actual error condition. This might be a write-protected tape, a physical I/O error, an end-of-tape condition, or a file too large limitation.
In the case of write-protected tapes, enable the write switch. For physical I/O errors, the best course of action is to replace the tape with a new one. For end-of-tape conditions, try using a higher density if the device supports one, or use cpio(1) or pax(1) for their multi-volume support. When encountering file too large limitations, use the parent shell's limit(1) or ulimit(1) facility to increase the maximum file size.
For more information on tar tapes, see the section on copying UFS files in the System Administration Guide, Volume I.
