At boot time the /etc/rcS script runs the fsck(1M) command to check the integrity of filesystems marked "fsck" in /etc/vfstab. If fsck(1M) cannot repair a filesystem automatically, it interrupts the boot procedure and produces this message. When fsck(1M) gets into this state, it cannot repair filesystems without losing one or more files, so it wants to defer this responsibility to you, the administrator. Data corruption has probably already occurred.
First run fsck -n on the filesystem, to see how many and what type of problems exist. Then run fsck(1M) again to repair the filesystem. If you have a backup of the filesystem, you can generally answer "y" to all the fsck(1M) questions. It's a good idea to keep a record of all problematic files and inode numbers for later reference. To run fsck(1M) yourself, specify options as recommended by the boot script. For example:
# fsck /dev/rdsk/c0t4d0s0 |
If you don't have a backup, ask an expert to run fsck(1M) for you.
For more information, see the section on checking filesystem integrity in the System Administration Guide, Volume I.
