While using Firewall v2.0, the following sequence happpens:
# telnet firewall-machine Trying 192.29.174.60 ... Connected to firewall-machine Escape character is '^]'. CheckPoint FireWall-1 authenticated Telnet server running on firewall-machine Login: testuser This gateway does not support Unix Password. |
Under Network Objects, edit your Gateway object, Host Properties Auth Schemes and select Unix Password. UNIX Password is not checked by default as it is considered an unsecure method of authentication.
