To fix:
1. Check SCSI bus for illegal configuration, bad cables, and duplicate SCSI addresses;
2. Boot from cdrom in single user.
OK boot cdrom -sw |
3. Attempt to fsck(1M) boot disk. This will probably fail with a superblock error.
# fsck /dev/rdsk/device |
4. Find out locations of alternate superblocks. BE SURE TO USE AN UPPERCASE -N. For example:
# newfs -N /dev/rdsk/c0t0d0s0 /dev/rdsk/c0t0d0s0: 2048960 sectors in 1348 cylinders of 19 tracks, 80 sectors 1000.5MB in 85 cyl groups (16 c/g, 11.88MB/g, 5696 i/g) super-block backups (for fsck -F ufs -o b=#) at: 32, 24432, 48832, 73232, 97632, 122032, 146432, 170832, 195232, 219632, 244032, 268432, 292832, 317232, 341632, 366032, 390432, 414832, 439232, 463632, 488032, 512432, 536832, 561232, 585632, 610032, 634432, 658832, 683232, 707632, 732032, 756432, 778272, 802672, 827072, 851472, 875872, 900272, 924672, 949072, 973472, 997872, 1022272, 1290672, ... |
5. Using an alternate superblock, fsck(1M) the disk. You may have to try more than one alternate superblock to get this to work. Pick a couple from the beginning, the middle, and the end.
# fsck -o b=<altblk> /dev/rdsk/c0t0d0s0 |
6. The boot block is probably bad too. Restore it while we are booted from the cdrom.
# /usr/sbin/installboot /usr/platform/architecture/lib/fs/ufs/bootblk /dev/rdsk/c0t0d0s0 |
7. Reboot the O.S. Should come up now.
# reboot |
