When compiling some code for BSD compatibility the error happened after invoking usr/ucb/cc. The unbundled compiler (SPARCworks Professional C product) was installed in /opt.
/usr/ucb/cc is a script which checks for the file /usr/ccs/bin/ucbcc and, if found, invokes it with appropriate library flags for BSD-compatibility compilation.
/usr/ucb/cc is part of the package SUNWscpu. /usr/ccs/bin/ucbcc is supposed to be a symbolic link to /opt/SUNWspro/bin/acc, which is created during installation of the unbundled C compiler, SPROcc.
