The user ID or group ID of an IPC object or file system object was too large to be stored in an appropriate member of the caller-provided structure.
Run the application on a newer system, or ask the program's author to fix this condition.
This error occurs only on systems that support a larger range of user or group ID values than a declared member structure can support. This condition usually occurs because the IPC or file system object resides on a remote machine with a larger value of type uid_t, off_t, or gid_t than that of the local system.
The symbolic name for this error is EOVERFLOW, errno=79.
