You must meet the minimum requirements to encapsulate a disk:
1. You must have two free, zero length, slices on the disk (no cylinders should be assigned to these slices.)
2. You must have two free cylinders on the disk. These 2 cylinders must not be in use by any slice other than slice two.
3. The two free cylinders must be located at the beginning or end of the drive.
