Look for some other message that might help diagnose the problem. By itself, a watchdog reset doesn't provide enough information; because traps are disabled, all information has been lost. If all that appears on the console is an ok prompt, issue the PROM command below to view the final messages that occurred just before system failure:
ok f8002010 wector p |
The result is a display of messages similar to those produced by the dmesg(1M) command. These messages can be useful in finding the cause of system failure.
