This means that I/O with the X server has been broken. The "0.0" represents the display device, which is usually the console. This message can appear when a user is running Display PostScript applications and the X server disappears or the client is shut down. Data loss is possible if applications disappeared before saving files.
Try to run the application again in a few minutes after the system has rebooted and the window system is running.
