The fsck(1M) command is checking a filesystem, and fsck(1M) is now verifying the integrity of directories. You might be asked to adjust, create, expand, reallocate, or reconnect directories.
You can usually answer yes to all these questions without harming the filesystem.
For more information, see the chapter on checking filesystem integrity in the System Administration Guide, Volume I.
