The fsck(1M) command is checking a filesystem, and fsck(1M) is now checking the free-block and used-inode maps. You might be asked to salvage free blocks or summary information.
You can usually answer yes to all these questions without harming the filesystem.
For more information, see the chapter on checking filesystem integrity in the System Administration Guide, Volume I.
