Action
The problem lies in the /tftpboot directory of the boot server. Confirm that the HOSTID and HOSTID.ARCH files are linked to the correct inetboot file for your architecture. The following is an example of how a symbolic link should look:
# cd /tftpboot
# ls -l 81971904*
81971904 -> inetboot.sun4m.Solaris_2.4
81971904.SUN4M -> inetboot.sun4m.Solaris_2.4
The following is an example of an incorrect entry for a sun4m system:
C753002F -> inetboot.axil4m.Solaris_2.5.1
C753002F.AXIL4M -> inetboot.axil4m.Solaris_2.5.1
If the entries are not correct, remove the entry for the particular client in this directory, using
rm_install_client or
rm_client commands, and re-add the client with the
add_install_client(1M) or
add_client command or through
Solstice giving the correct architecture.
