The lower (linked) queue read put procedure is:
static int
muxlrput(queue_t *q, mblk_t *mp)
queue_t *uq;
int device;
if(muxerr) {
freemsg(mp);
return (0);
switch(mp->b_datap->db_type) {
case M_FLUSH:
* Flush queues. NOTE: sense of tests is reversed
* since we are acting like a "stream head"
if (*mp->b_rptr & FLUSHW) {
*mp->b_rptr &= ~FLUSHR;
qreply(q, mp);
} else
freemsg(mp);
break;
case M_ERROR:
case M_HANGUP:
muxerr = 1;
freemsg(mp);
break;
case M_DATA:
* Route message. First byte indicates
* device to send to. No flow control.
* Extract and delete device number. If the
* leading block is now empty and more blocks
* follow, strip the leading block.
device = *mp->b_rptr++;
/* Sanity check. Device must be in range */
if (device < 0 || device >= mux_cnt) {
freemsg(mp);
break;
* If upper stream is open and not backed up,
* send the message there, otherwise discard it.
uq = mux_mux[device].qptr;
if (uq != NULL && canputnext(uq))
putnext(uq, mp);
else
freemsg(mp);
break;
default:
freemsg(mp);
return (0);
muxlrput receives messages from the linked Stream. In this case, it is acting as a Stream head. It handles M_FLUSH messages. Note the code is the reverse of a driver, handling M_FLUSH messages from upstream. There is no need to flush the read queue because no data is ever placed in it.
muxlrput also handles M_ERROR and M_HANGUP messages. If one is received, it locks up the upper Streams by setting muxerr.
M_DATA messages are routed by checking the first data byte of the message. This byte contains the minor device of the upper Stream. Several sanity checks are made:
Check whether the device is in range
Check whether the upper Stream is open
Check whether the upper Stream is full
This multiplexer does not support flow control on the read side; it is merely a router. If it passes all checks, the message is put to the proper upper queue. Otherwise, the message is discarded.
The upper Stream close routine clears the mux entry so this queue will no longer be found. Outstanding bufcalls are not cleared.
* Upper queue close
static int
muxclose(queue_t *q, int flag, cred_t *credp)
struct mux *mux;
mux = (struct mux *) q->q_ptr;
qprocsoff(q);
if (mux->bufcid != 0)
unbufcall(mux->bufcid);
mux->bufcid = 0;
mux->ptr = NULL;
q->q_ptr = NULL;
WR(q)->q_ptr = NULL;
return(0);
