If a Stream supports a terminal interface, a driver or module that understands all ioctls is needed to support terminal semantics (specified by termio(7I) and termiox(7I). If there is no hardware driver that understands all ioctl commands downstream from the ldterm module, a hardware emulation module must be placed downstream from the line discipline module. The function of the hardware emulation module is to understand and acknowledge the ioctls that may be sent to the process at the Stream head and to mediate the passage of control information downstream. Together, the line-discipline module and the hardware emulation module behaves as if there was an actual terminal on that Stream.
The hardware emulation module is necessary whenever there is no TTY driver at the end of the Stream. For example, the module is necessary in a pseudo-TTY situation where there is process-to-process communication on one system (this is discussed later in this chapter), or in a network situation where a termio interface is expected (for example, remote login) but there is no TTY driver on the Stream.
Most of the actions taken by the hardware emulation module are the same regardless of the underlying architecture. However, there are some actions that are different, depending on whether the communication is local or remote and whether the underlying transport protocol is used to support the remote connection.
Each hardware emulation module has an open, close, read queue put procedure, and write queue put procedure.
The hardware emulation module does the following:
Processes, if appropriate, and acknowledges receipt of the following ioctls on its write queue by sending an M_IOCACK message back upstream: TCSETA, TCSETAW, TCSETAF, TCSETS, TCSETSW, TCSETSF, TCGETA, TCGETS, and TCSBRK.
Acknowledges the Extended UNIX Code (EUC) ioctl(2).
If the environment supports windowing, it acknowledges the windowing TIOCSWINSZ, TIOCGWINSZ, and JWINSIZE ioctl(2)s. If the environment does not support windowing, an M_IOCNAK message is sent upstream.
If another ioctl(2) is received on its write queue, it sends an M_IOCNAK message upstream. It doesn't pass any unrecognized ioctl(2) to the slave driver.
When the hardware emulation module receives an M_IOCTL message of type TCSBRK on its write queue, it sends an M_IOCACK message upstream and the appropriate message downstream. For example, an M_BREAK message could be sent downstream.
When the hardware emulation module receives an M_IOCTL message on its write queue to set the baud rate to 0 (TCSETAW with CBAUD set to B0), it sends an M_IOCACK message upstream and an appropriate message downstream; for networking situations this will probably be an M_PROTO message, which is a TPI T_DISCON_REQ message requesting the transport provider to disconnect.
All other messages (M_DATA, for instance) not mentioned here are passed to the next module or driver in the Stream.
The hardware emulation module processes messages in a way consistent with the driver that exists.
