A reference is represented by the type FN_ref_t. An object of this type contains a reference type and a list of addresses. The ordering in this list at the time of binding might not be preserved when the reference is returned upon lookup.
The reference type is represented by an object of type FN_identifier_t. The reference type is intended to identify the class of object referenced, but XFN does not dictate its precise use.
Each address in a reference is represented by an object of type FN_ref_addr_t. An address consists of an opaque data buffer and a type field, again of type FN_identifier_t. The address type is intended to identify the mechanism that should be used to reach the object using that address.
Multiple addresses in a single reference are intended to identify multiple communication endpoints for the same conceptual object. Multiple addresses can arise for various reasons; for example, because the object offers interfaces over more than one communication mechanism.
The client process must interpret the contents of the opaque buffers based on the type of the address and on the type of the reference. However, this interpretation is intended to occur below the application layer.
Most application developers should not be required to manipulate the contents of either address or reference objects themselves. These interfaces are generally used within service libraries.
