Federated Naming Service Programming Guide
Attribute Search Interface
The search interface contains several operations: a basic search operation, which performs associative lookup in a single context, and an extended search operation that allows the search criteria to be specified using an expression . It also allows the scope of the search to encompass a wider scope than only a single context.
Basic Search
This set of operations is used to enumerate names of objects bound in the target context named name relative to the context ctx with attributes whose values match all those specified by match_attrs. Using return_ref specifies whether to return the references of named objects in the search, while return_attr_ids specifies the attributes to be returned in the search.
FN_searchlist_t *fn_attr_search(
    FN_ctx_t *ctx,
    const FN_composite_name_t *name,
    const FN_attrset_t *match_attrs,
    unsigned int return_ref,
    const FN_attrset_t *return_attr_ids,
    FN_status_t *status);
FN_string_t *fn_searchlist_next(
    FN_searchlist_t *sl,
    FN_ref_t **returned_ref,
    FN_attrset_t **returned_attrs,
void fn_searchlist_destroy(
    FN_searchlist_t *sl);
The call to fn_attr_search() initiates the search in the target context. It returns a handle to an FN_searchlist_t object that is used to enumerate the names of the objects whose attributes match match_attrs.
fn_searchlist_next() returns the next name in the enumeration identified by sl. The reference of the name, if requested, is returned in returned_ref. The attributes specified by return_attr_ids are returned in returned_attrs. Successive calls to fn_searchlist_next() using sl return successive names, and optionally, references and attributes in the enumeration and further update the state of the enumeration.
fn_searchlist_destroy() releases resources used during the enumeration. It can be called at any time to terminate the enumeration.
Extended Search
This set of operations is used to list names of objects whose attributes satisfy the filter expression filter. The control argument encapsulates the option settings for the search.
FN_ext_searchlist_t *fn_attr_ext_search(
    FN_ctx_t *ctx,
    const FN_composite_name_t *name,,
    const FN_search_control_t *control
FN_composite_name_t *fn_ext_searchlist_next(
    FN_ext_searchlist_t *esl,
void fn_ext_searchlist_destroy(
    FN_ext_searchlist_t *esl);
These options are:
  1. The scope of the search. This can be any of the following:
    • Search the named object
    • sSearch the context named by name
    • Search the entire subtree rooted at the context named by name
    • Ssearch the context implementation-defined subtree rooted at the context named by name.
  2. Whether XFN links are followed during the search
  3. A limit on the number of names returned
  4. Whether the reference associated with the named object is returned
  5. Which attributes associated with the named object are returned
The filter expression is evaluated against the attributes of the objects bound in the scope of the search. The filter evaluates to either true or false.
The call to fn_attr_ext_search() initiates the search and, if successful, returns a handle to an FN_ext_searchlist_t object, esl, that is used to enumerate the names of the objects that satisfy the filter.
fn_ext_searchlist_next() returns the next name, and optionally, its reference and attributes, in the enumeration identified by esl. The name returned is a composite name, to be resolved relative to the starting context for the search. The starting context is the context named name relative to ctx, unless the scope of the search is only the named object. If the scope of the search is only the named object, the teriminal atomic name is returned. Successive calls to fn_ext_searchlist_next() using esl return successive names, and optionally, references and attributes, in the enumeration and further update the state of the enumeration.
fn_ext_searchlist_destroy() releases resources used during the search and enumeration. It can be called at any time to terminate the enumeration.
