This set of operations allows the caller to obtain attribute values associated individually with a single attribute.
This set of operations is used to obtain the set of values of a single attribute, identified by attribute_id, associated with name, relative to ctx. If name is empty, the attribute associated with ctx is obtained.
This interface should be used instead of fn_attr_get() if the combined size of all the values is expected to be too large to be returned by fn_attr_get().
The operation fn_attr_get_values() initiates the enumeration process. It returns a handle to an FN_valuelist_t object that can be used for subsequent fn_valuelist_next() calls to enumerate the values requested.
The operation fn_valuelist_next() returns the next attribute value in the enumeration and updates vl to indicate the state of the enumeration.
The operation fn_valuelist_destroy() frees the resources associated with the enumeration. This operation can be invoked at any time to terminate the enumeration.
