The following section explains each layer the OSI reference model.
This layer specifies the physical media connecting hosts and networks, and the procedures used to transfer data between machines using a specified media. This layer is commonly referred to as the hardware layer of the model.
This layer manages the reliable delivery of data across the physical network. For example, it provides the abstraction of a reliable connection over the potentially unreliable physical layer.
This layer is responsible for routing machine-to-machine communications. It determines the path a transmission must take, based upon the destination machine's address. This layer must also respond to network congestion problems.
This layer provides end-to-end sequenced delivery of data. It is the lowest layer that provides applications and higher layers with end-to-end service. This layer hides the topology and characteristics of the underlying network from users. It provides reliable end-to-end data delivery if the service characteristics require it.
This layer manages sessions between cooperating applications.
This layer performs the translation between the data representation local to the computer and the processor-independent format that is sent across the network. It can also negotiate the transfer formats in some protocol suites. Typical examples include standard routines that compress text or convert graphic images into bit streams for transmission across a network.
This layer consists of the user-level programs and network services. Some examples are telnet, ftp, and tftp.
