NETPATH Environment VariableAn application usually uses the default transport search path set by the system administrator to locate an available transport. However, when a user wants to influence the choices made by an application, the application can modify the interface by using the environment variable NETPATH and the routines described in the section, "NETPATH Access to netconfig Data". These routines access only the transports specified in the NETPATH variable.
NETPATH is similar to the PATH variable. It is a colon-separated list of transport IDs. Each transport ID in the NETPATH variable corresponds to the network ID field of a record in the netconfig file. NETPATH is described in the environ(4) man page.
The default transport set is different for the routines that access netconfig through the NETPATH environment variable (described in the next section) and the routines that access netconfig directly. The default transport set for routines that access netconfig via NETPATH consists of the visible transports in the netconfig file. For routines that access netconfig directly, the default transport set is the entire netconfig file. A transport is visible if the system administrator has included a v flag in the flags field of that transport's netconfig entry.
