Figure 2-1 and the next two examples illustrate initiating and accepting an Internet domain stream connection.
The program in Example 2-2 is a server. It creates a socket and binds a name to it, then displays the port number. The program calls listen() to mark the socket ready to accept connection requests and initialize a queue for the requests. The rest of the program is an infinite loop. Each pass of the loop accepts a new connection and removes it from the queue, creating a new socket. The server reads and displays the messages from the socket and closes it. The use of INADDR_ANY is explained in "Address Binding".
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <netdb.h>
#include <stdio.h>
#define TRUE 1
* This program creates a socket and then begins an infinite loop.
* Each time through the loop it accepts a connection and prints
* data from it. When the connection breaks, or the client closes
* the connection, the program accepts a new connection.
main()
int sock, length;
struct sockaddr_in server;
int msgsock;
char buf[1024];
int rval;
/* Create socket. */
sock = socket(AF_INET, SOCK_STREAM, 0);
if (sock == -1) {
perror("opening stream socket");
exit(1);
/* Bind socket using wildcards.*/
server.sin_family = AF_INET;
server.sin_addr.s_addr = INADDR_ANY;
server.sin_port = 0;
if (bind(sock, (struct sockaddr *) &server, sizeof server)
== -1) {
perror("binding stream socket");
exit(1);
/* Find out assigned port number and print it out. */
length = sizeof server;
if (getsockname(sock,(struct sockaddr *) &server,&length)
== -1) {
perror("getting socket name");
exit(1);
printf("Socket port #%d\n", ntohs(server.sin_port));
/* Start accepting connections. */
listen(sock, 5);
do {
msgsock = accept(sock,(struct sockaddr *) 0,(int *) 0);
if (msgsock == -1
perror("accept");
else do {
memset(buf, 0, sizeof buf);
if ((rval = read(msgsock,buf, 1024)) == -1)
perror("reading stream message");
if (rval == 0)
printf("Ending connection\n");
else
/* assumes the data is printable */
printf("-->%s\n", buf);
} while (rval > 0);
close(msgsock);
} while(TRUE);
* Since this program has an infinite loop, the socket "sock" is
* never explicitly closed. However, all sockets will be closed
* automatically when a process is killed or terminates normally.
exit(0);
To initiate a connection, the client program in Example 2-3 creates a stream socket and calls connect(), specifying the address of the socket for connection. If the target socket exists and the request is accepted, the connection is complete and the program can send data. Data are delivered in sequence with no message boundaries. The connection is destroyed when either socket is closed. For more information about data representation routines, such as ntohl(), ntohs(), htons(), and htonl(), in this program, see the byteorder(3N) man page.
#include <netdb.h>
#include <stdio.h>
#define DATA "Half a league, half a league . . ."
* This program creates a socket and initiates a connection with
* the socket given in the command line. Some data are sent over the
* connection and then the socket is closed, ending the connection.
* The form of the command line is: streamwrite hostname portnumber
* Usage: pgm host port
main(argc, argv)
int argc;
char *argv[];
int sock;
struct hostent *hp, *gethostbyname();
char buf[1024];
sock = socket( AF_INET, SOCK_STREAM, 0);
if (sock == -1) {
exit(1);
/* Connect socket using name specified by command line. */
hp = gethostbyname(argv[1] );
* gethostbyname returns a structure including the network address
* of the specified host.
if (hp == (struct hostent *) 0) {
fprintf(stderr, "%s: unknown host\n", argv[1]);
exit(2);
memcpy((char *) &server.sin_addr, (char *) hp->h_addr,
hp->h_length);
server.sin_port = htons(atoi(argv[2]));
if (connect(sock, (struct sockaddr *) &server, sizeof server)
== -1) {
perror("connecting stream socket");
exit(1);
if (write( sock, DATA, sizeof DATA) == -1)
perror("writing on stream socket");
close(sock);
exit(0);
