Asynchronous communication between processes is required in applications that handle multiple requests simultaneously. Asynchronous sockets must be SOCK_STREAM type. To make a socket asynchronous, you issue a fcntl() call, as shown in Example 2-15.
#include <fcntl.h>
#include <sys/file.h>
int fileflags;
int s;
s = socket(AF_INET, SOCK_STREAM, 0);
if (fileflags = fcntl(s, F_GETFL ) == -1)
perror("fcntl F_GETFL");
exit(1);
if (fcntl(s, F_SETFL, fileflags | FNDELAY | FASYNC) == -1)
perror("fcntl F_SETFL, FNDELAY | FASYNC");
exit(1);
After sockets are initialized, connected, and made asynchronous, communication is similar to reading and writing a file asynchronously. A send(), write(), recv(), or read() initiates a data transfer. A data transfer is completed by a signal-driven I/O routine, described in the next section.
