The following procedure is a sample ProcessOnItemHelp() function that would be invoked by choosing On Item from the Help menu.
void ProcessOnItemHelp(
Widget widget)
/* Declare a variable for the selected widget. */
Widget selWidget=NULL;
int status=DtHELP_SELECT_ERROR;
/* Get an application shell widget from our widget hierarchy to
* pass into DtHelpReturnSelectedWidgetId().
while (!XtIsSubclass(widget, applicationShellWidgetClass))
widget = XtParent(widget);
status = DtHelpReturnSelectedWidgetId(widget, NULL, &selWidget);
switch ((int)status)
case DtHELP_SELECT_ERROR:
printf("Selection Error, cannot continue\n");
break;
case DtHELP_SELECT_VALID:
/* We have a valid widget selection, now let's look for a registered help
* callback to invoke.
while (selWidget != NULL)
if ((XtHasCallbacks(selWidget, XmNhelpCallback)
== XtCallbackHasSome))
/* Found a help callback, so just call it */
XtCallCallbacks((Widget)selWidget,
XmNhelpCallback,NULL);
break;
else
/* No help callback on current widget, so try the widget's parent */
selWidget = XtParent(selWidget);
break;
case DtHELP_SELECT_ABORT:
printf("Selection Aborted by user.\n");
break;
case DtHELP_SELECT_INVALID:
printf("You must select a component within your app.\n");
break;
