A sample formatting table for a multibyte character set is located in the /usr/dt/dthelp/nls/zh_CN.dt-eucCN directory and is named fmt_tbl.msg.
The sample table can be modified by adding or removing characters. To edit the formatting table, use an editor capable of composing characters in the language you have chosen for the help information. If you intend to create help information using a multibyte language, you need to create a formatting table.
