ID strings may contain letters (A - Z and a - z), digits (0 - 9), and the minus (-) sign, and must begin with a letter.
Author-defined IDs may not use the _ (underscore character); it is reserved for IDs that are built into some HelpTag elements.
Case is not significant, but is often used to increase readability.
ID strings cannot be longer than 64 characters.
Each ID within a single help volume must be unique.
