This formal markup sample is an excerpt from the desktop Text Editor help volume. To view the corresponding online information, choose the Help Viewer in the Front Panel. Select Common Desktop Environment and then choose Text Editor Help from the listed volumes. In the Text Editor volume, choose Text Editor Tasks and then To Open an Existing Document.
Indentation is used in this example to make it easier to read the text and corresponding element tags.
<s2 id="TOOPENANEXISTINGDOCUMENT">
<chaphead><head>
<partext>To Open an Existing Document</partext>
     </head></chaphead>
<text>
<p>
<partext>You can use Text Editor or File Manager to open an existing
document.
 </partext></p>
<idx><indexprimary>
<partext>document</partext></indexprimary>
     <indexsub>
<partext>opening</partext></indexsub></idx>
<idx><indexprimary>
<partext>opening</partext></indexprimary>
     <indexsub>
<partext>existing document</partext></indexsub></idx>
<procedure>
<chaphead><head>
<partext>From Text Editor</partext>
     </head></chaphead>
<text>
<list type="ORDER">
<item><text><p>
<partext>Choose Open from the File menu.</partext></p>
<p>
<partext>The Open a File dialog box lists files and folders on your
system.You can browse the documents listed, or change to a new folder
to locate other files on your system.</partext>
     </p></text></item>
<item><text><p>
<partext>Select the document you want to open in the Files list or
type the file name in the Open a File field.</partext></p>
<p>
<partext><emph><partext>Or,</partext></emph> if the document is not
in the current folder, first change to the folder that contains your
document. Then choose a name in the Folders list or type the path
name of the folder you wish to change to in the Enter path or folder
name field.</partext></p></text></item>
<item><text><p>
<partext>Press Return or click OK.
 </partext></p></text></item></list>
<figure tonumber="NONUMBER" entity="TEXTEDITOROPENFILE">
</figure></text></procedure>
<procedure><chaphead><head>
<partext>From File Manager</partext>
     </head></chaphead>
<idx><indexprimary>
     <indexsub>
<partext>document from File Manager</partext></indexsub></idx>
<idx><indexprimary>
     <indexsub>
<partext>opening from File Manager</partext></indexsub></idx>
<idx><indexprimary>
<partext>File Manager</partext></indexprimary>
     <indexsub>
<partext>opening document</partext></indexsub></idx>
<text>
<list type="BULLET">
<item><text><p>
<partext>Display the document's file icon in a File Manager
window.</partext>
     </p></text></item>
<item><text><p>
<partext>Do <emph><partext>one</partext></emph> of the
following:</partext></p>
<item><text><p>
<partext>Double-click the document's file icon.</partext>
     </p></text></item>
<item><text><p>
<partext>Select the document, then choose Open from the Selected
menu.</partext>
     </p></text></item>
<item><text><p>
<partext>Drag the document to Text Editor's control in the Front
Panel.</partext>
     </p></text></item></list></text>
     </item></list><text> </procedure>
<partext>See Also</partext>
     </head></chaphead>
<text>
<list type="BULLET" spacing="TIGHT">
<item><text><p>
<partext><xref id="ENTERINGANDEDITINGTEXT"></partext>
     </p></text></item>
<item><text><p>
<partext><xref id="TOSAVEADOCUMENTTOTHECURRENTFILE"></partext>
     </p></text></item>
<item><text><p>
<partext><xref id="TABLEOFCONTENTS"></partext>
     </procedure></text></s2>
