Name |
Class/Type |
Access |
Default Value |
XmNfontType |
XmCFontType/XmFontType |
CSG |
XmAS_IS |
XmNlayoutAttrObject |
XmClayoutAttrObject/String |
CG |
NULL |
XmNlayoutModifier |
XmCLayoutModifier/String |
CSG |
NULL |
Specifies the type of the Rendition font object. For CTL, the value of this resource must be the XmFONT_IS_XOC value. If it is not, then the XmNlayoutAttrObject and XmNlayoutModifier resources are ignored.
When the value of this resource is XmFont_IS_XOC, and if the XmNfont resource is not specified, then at create time the value of the XmNfontName resource gets converted into an XOC object in either the locale specified by the XmNlayoutAttrObject resource or the current locale. Furthermore, the value of the XmNlayoutModifier resource gets passed through to any LayoutObject associated with the XOC.
Specifies the layout AttrObject argument to be used to create the Layout Object associated with the XOC associated with this XmRendition. Refer to the Layout Services m_create_layout() specification for the syntax and semantics of this string. (See the description of XmNfontType above for an explanation of the interaction between the Layout Modifier Orientation output value and the XmNlayoutDirection widget resource.)
Specifies the layout values to be passed through to the Layout Object associated with the XOC associated with this XmRendition. For the syntax and semantics of this string, see CAE Specification.
Setting this resource using XmRendition{Retrieve,Update} causes the string to be passed through to the LayoutObject associated with the XOC associated with this Rendition. This is the mechanism for configuring layout services dynamically. Note that unpredictable behavior may result if the Orientation, Context, TypeOfText, TextShaping, or ShapeCharset are changed.
