The following new resources are added to XmText and XmTextField:
Name |
Class/Type |
Access |
Default Value |
XmNrenditionTag |
XmCRenditionTag/XmRString |
CSG |
XmFONTLIST_DEFAULT_TAG |
XmNalignment |
XmCAlignment/XmRAlignment |
CSG |
XmALIGNMENT_BEGINNING |
XmNeditPolicy |
XmCEditPolicy/XmREditPolicy |
CSG |
XmEDIT_LOGICAL |
Specifies the rendition tag of the XmRendition (in the XmNrenderTable resource) to be used for this widget.
Specifies the text alignment to be used in the widget. Only XmALIGNMENT_END and XmALIGNMENT_CENTER are supported.
Specifies the editing policy to be used for the widget, either XmEDIT_LOGICAL or XmEDIT_VISUAL. In the case of XmEDIT_VISUAL, selection, cursor movement, and deletion are in a visual style. Setting this resource also changes the translations for the standard keyboard movement and deletion events either to the new "visual" actions list below or to the existing logical actions.
