The XmText action routines are as follows:
If the XmNeditPolicy is XmEDIT_LOGICAL and is called without arguments, it moves the insertion cursor back logically by a character. If the insertion cursor is at the beginning of the line, it moves the insertion cursor to the logical last character of the previous line if one exists, otherwise the insertion cursor position doesn't change.
If the XmNeditPolicy is XmEDIT_VISUAL, then the cursor moves to the left of cursor position. If the insertion cursor is at the beginning of the line, then it moves to the end character of the previous line if one exists.
If it is called with an extend argument, it moves the insertion cursor as in the case of no argument and extends the current selection.
The left-character() action produces calls to the XmNmotionVerifyCallback procedures with the reason value XmCR_MOVING_INSERT_CURSOR. If called with an extend argument, this may produce calls to the XmNgainPrimaryCallback procedures. See the callback description in the Motif Programmer's Reference for more information.
If the XmNeditPolicy is XmEDIT_LOGICAL and is called without any arguments, and the insertion cursor is at the logical starting of the word, it moves the insertion cursor to the logical starting of the logical preceding word, if one exists, otherwise the insertion cursor position doesn't change. If the insertion cursor is in the word but not at the logical start of the word, it moves the insertion cursor to the logical start of the word. If the insertion cursor is at the logical start of the line, it moves the insertion cursor to the logical start of the logical last word in the previous line if one exists, otherwise the insertion cursor position doesn't change.
If the XmNeditPolicy is XmEDIT_VISUAL and is called without arguments, it moves the insertion cursor to the first non-white space character after the first white space character to the left or after the beginning of the line. If the insertion cursor is already at the beginning of the word, it moves the insertion cursor to the beginning of the previous word. If the insertion cursor is already at the beginning of the line, it moves to the starting of the last word in the previous line.
If called with an argument of extend, it moves the insertion cursor as in the case of no argument and extends the current selection.
The left-word() action produces calls to the XmNmotionVerifyCallback procedures with the reason value XmCR_MOVING_INSERT_CURSOR. If it is called with an extend argument, this may produce calls to the XmNgainPrimaryCallback procedures. See the callback description in the Motif Programmer's Reference for more information.
If the XmNeditPolicy is XmEDIT_LOGICAL and is called without any arguments, it moves the insertion cursor logically forward by a character. If the insertion cursor is at the logical end of the line, it moves the insertion cursor to the logical starting of the next line, if one exists.
If the XmNeditPolicy is XmEDIT_VISUAL, then the cursor moves to the right of cursor position. If the insertion cursor is at the end of the line, it moves the insertion cursor to the starting of the next line, if one exists.
The right-character() action produces calls to the XmNmotionVerifyCallback procedures with the reason value XmCR_MOVING_INSERT_CURSOR. If called with extend argument, this may produce calls to the XmNgainPrimaryCallback procedures. See the callback description in the Motif Programmer's Reference for more information.
If the XmNeditPolicy is XmEDIT_LOGICAL and is called without any arguments, it moves the insertion cursor to the logical starting of the logical succeeding word if one exists, otherwise it moves to the logical end of the current word. If the insertion cursor is at the logical end of the line or in the logical last word of the line, it moves the cursor to the logical first word in the next line if one exists, otherwise it moves to the logical end of the current word.
If the XmNeditPolicy is XmEDIT_VISUAL and is called without arguments, it moves the insertion cursor to the first nonwhite space character after the first white space character to the right or after the end of the line.
The left-word() action produces calls to the XmNmotionVerifyCallback procedures with the reason value XmCR_MOVING_INSERT_CURSOR. If called with extend argument, this may produce calls to the XmNgainPrimaryCallback procedures. See the callback description in the Motif Programmer's Reference for more information.
If the XmNeditPolicy is XmEDIT_LOGICAL, it is equivalent to delete-previous-char. If the XmNeditPolicy is XmEDIT_VISUAL, then in normal mode, if there is a non-null selection, it deletes the selection; otherwise it deletes the character left of the insertion cursor. In add mode, if there is a non-null selection, the cursor is not disjointed from the selection and XmNpendingDelete is set to True, it deletes the selection; otherwise it deletes the character left of the insertion cursor. This may impact the selection.
The delete-left-character() action produces calls to the XmNmodifyVerifyCallback procedures with reason value XmCR_MODIFYING_TEXT_VALUE and the XmNvalueChangedCallback procedures with reason value XmCR_VALUE_CHANGED.
If the XmNeditPolicy is XmEDIT_VISUAL, it is equivalent to delete-next-character. If the XmNeditPolicy is XmEDIT_VISUAL, then in normal mode, if there is a non-null selection, it deletes the selection; otherwise, it deletes the character right of the insertion cursor. In add mode, if there is a non-null selection and the cursor is not disjointed from the selection, the XmNpendingDelete is set to True and the selection is deleted; otherwise, the character right of the insertion cursor is deleted. This may impact the selection.
The delete-right-character() action produces calls to the XmNmodifyVerify- Callback procedures with reason value XmCR_MODIFYING_TEXT_VALUE, and the XmNvalue- ChangedCallback procedures with reason value XmCR_VALUE_CHANGED.
If the XmNeditPolicy is XmEDIT_VISUAL, it is equivalent to delete-prev-word(). If the XmNeditPolicy is XmEDIT_LOGICAL, then in normal mode, if there is a non-null selection, it deletes the selection; otherwise, it deletes the characters left of the insertion cursor to the next space, punctuation character, tab, or beginning-of-line character. In add mode, if there is a non-null selection, the cursor is not disjointed from the selection; otherwise it deletes the characters left of the insertion cursor the right space, tab, or beginning-of-line character. In add mode, if there is a non-null selection, the cursor is not disjointed from the selection, the XmNpendingDelete is set to True, and the selection is deleted; otherwise, it deletes the character left of the insertion cursor, the right space, tab, or beginning of new-line character. This may impact the selection.
If the XmNeditPolicy is XmEDIT_VISUAL, it is equivalent to delete-right-word(). If the XmNeditPolicy is XmEDIT_LOGICAL, then in normal mode, if there is a non-null selection, it deletes the selection; otherwise, it deletes the characters right of the insertion cursor to the next space, punctuation character, tab, or end-of-line character. In add mode, if there is a non-null selection, the cursor is not disjointed from the selection, XmNpendingDelete is set to True, and deletes the selection; otherwise, it deletes the characters right of the insertion cursor to the next space, tab, or end-of-line character. This may impact the selection.
If the XmNeditPolicy is XmEDIT_LOGICAL, it is equivalent to kill-prev-char. If the XmNeditPolicy is XmEDIT_VISUAL, then in normal mode, if there is a non-null selection, it deletes the selection; otherwise, it kills the character left of the insertion cursor and stores the character in the cut buffer. In add mode, if there is a non-null selection, the cursor is not disjointed from the selection, XmNpendingDelete is set to True, and deletes the selection; otherwise, it deletes the character left of the insertion cursor. This may impact the selection.
The kill-left-character() action produces calls to the XmNmodifyVerifyCallback procedures with the reason value XmCR_MODIFYING_TEXT_VALUE, and produces the XmNvalueChangedCallback procedures with the reason value XmCR_VALUE_CHANGED.
If the XmNeditPolicy is XmEDIT_VISUAL, it is equivalent to delete-next-character. If the XmNeditPolicy is XmEDIT_VISUAL, then in normal mode, if there is a non-null selection, it deletes the selection; otherwise, it deletes the character right of the insertion cursor and stores it in the cut buffer. In add mode, if there is a non-null selection, the cursor is not disjointed from the selection, the XmNpendingDelete is set to True and deletes the selection; otherwise, it deletes the character right of the insertion cursor. This may impact the selection.
The kill-right-character() action produces calls to the XmNmodifyVerify-Callback procedures with reason value XmCR_MODIFYING_TEXT_VALUE, and produces calls to the XmNvalue-ChangedCallback procedures with reason value XmCR_VALUE_CHANGED.
If the XmNeditPolicy is XmEDIT_VISUAL, it is equivalent to delete-prev-word(). If the XmNeditPolicy is XmEDIT_LOGICAL, then in normal mode, if there is a non-null selection, it deletes the selection; otherwise, it deletes the characters left of the insertion cursor to the next space, punctuation character, tab, or beginning-of-line character. In add mode, if there is a non-null selection, the cursor is not disjointed from the selection; otherwise it deletes the characters left of the insertion cursor the right space, tab, or beginning-of-line character and stores it in the cut buffer. In add mode, if there is a non-null selection, the cursor is not disjointed from the selection, XmNpendingDelete is set to True and deletes the selection; otherwise it deletes the characters left of the insertion cursor the right space, tab, or beginning of new-line character. This may impact the selection.
If the XmNeditPolicy is XmEDIT_VISUAL, it is equivalent to delete-right-word(). If the XmNeditPolicy is XmEDIT_LOGICAL, then in normal mode, if there is a non-null selection, it deletes the selection; otherwise, it deletes the characters right of the insertion cursor to the next space, tab, or end-of-line character. In add mode, if there is a non-null selection, the cursor is not disjointed from the selection, XmNpendingDelete is set to True, and deletes the selection; otherwise, it deletes the characters right of the insertion cursor to the next space, punctuation character, tab, or end-of-line character and stores in the cut buffer. This may impact the selection.
A few cell-based routines are implemented to support character composition, ligatures, and diacritics. In other words, two or more characters might be represented by a single glyph occupying one presentation cell.
The XmText cell action routines are as follows:
Moves the insertion cursor back one cell. If the XmNeditPolicy is XmEDIT_LOGICAL, then the insertion cursor is moved to the start of the cell that precedes the current cell logically, if one exists; otherwise it moves to the start of the current cell.
If the XmNeditPolicy is XmEDIT_VISUAL, then the cursor moves to the start of cell to the left of the cursor, if one exists. The prev-cell() action produces calls to the XmNmotionVerifyCallback procedures with the reason value XmCR_MOVING_INSERT_CURSOR. If called with an extend argument, this may produce calls to the XmNgainPrimaryCallback procedures. See the callback description in the Motif Programmer's Reference for more information.
Moves the insertion cursor to the start of the logical next cell, if one exists; otherwise it moves it to the end of the cell. If the XmNeditPolicy is XmEDIT_LOGICAL, then the cursor moves forward one cell.
If the XmNeditPolicy is XmEDIT_VISUAL, then the cursor moves to the start of the cell to the right of the cursor position if one exits; otherwise it moves to the end of the current cell. The forward-cell() action produces calls to the XmNmotionVerifyCallback procedures with the reason value XmCR_MOVING_INSERT_CURSOR. If called with an extend argument, this may produce calls to the XmNgainPrimaryCallback procedures. See the callback description in the Motif Programmer's Reference for more information.
