The following example shows a command to install the SUNWaudio package from a CD mounted on the Solaris 2.6 operating environment or compatible versions. The example also shows use of the pkgchk command to verify that the package files were installed properly.
# pkgadd -d /cdrom/cdrom0/s0/Solaris_2.7/Product SUNWaudio . . . Installation of SUNWaudio> complete. # pkgchk -v SUNWaudio /usr /usr/bin /usr/bin/audioconvert /usr/bin/audioplay /usr/bin/audiorecord |
